RCU Forums - View Single Post - Gremlin maiden flight problem
Old 10-15-2004 | 02:52 PM
twister55
Default RE: Gremlin maiden flight problem
he heh hee
the madien flight of my gremlin[8D] started out ok ,
threw it upward at 30 deg at full throttle , it slowly climbed then, turned to the right flew nice and very solidly across my field of view
then it disapeared behind some trees [X(], it was too low darn it.[:-]
I tried to turn to the right and bring it back but all I head was a screaming engine whine and then a KRRRRRaaaaack plop mushhh
well it was spring and the field was ozzing wet.. mud packed right into the inside top of the 2 " spinner yuck!! mud every where , but it probably saved the plane--
after the acheological dig in wet spoil to find the bog germlin, I determined the following as contributors to the crash.
airplane combat gremlin engine k&b .20 prop 9X4 full size wing....... 2 inch elevons
the 2 inch elevons were too much , they helped in the initial climb out but when I throtelled back the wing stalled in a nose up attitude... stalling
adding right alieron put it in more of a spin followed by the whinnning engine scream into the kerplop
I could'nt see it behind those darn ed plane eating trees . and I should throlled back to zero ..... oh well only the wing was totaled that time []
