Well I done some work on the wings. Here are a few photos.
I just have to do alittle bit more sanding and I can join them.
I do have a problem. There is a step that you should not finish until you are ready to mate the wings with the fuselage. You need to leave off a bottom balsa sheet . well. i left a sheet off the bottom off one side and a top sheet off the other. I still should be able to do the work, but we'll see. I may have to strip a sheet!
Flyblueskies, could you have moved you battery around to compensate for the tail weight?
