Sig 4 Star 60 ARF
Hi Tony:
I bought the Sig Four Star 60 ARF. It was packaged very well and had no damage from shipping. Assembly was easy I built it in about two days.
The only problems I ran into were:
the holes in the fuse for the wing dowels were drilled to high, I used a round file to fix that
the control rods for the tail would would bind at the fuse exit, so I replaced the ny-rod with 36" Sullivan 4-40 steel rod(after people told me that the ny-rod would expand and contract with temp requiring trim changes with temperature)
The tube for the receiver antenna was too tight to feed the antenna all the way through.
These were very minor problems and the plane went together really well. I'll be flying it tonight, I'll let you know how it goes.
Stephen
