4 * 60
Have had several of the 4* 60 kits over the last few years and
they all flew very well. Incidently, if you are having problems
"pushing" your antenna through the tube, spray a little
silicone spray lube into the tube and the antenna will slip through
easily. Use the small spray tube that comes with the spray can to direct the spray. I have used this method for years.
