RE: Ever Seen this? Creek Hobbies Witch 3d profile
I think you mean Cedar Hobbies.
The plane looks as good as my profiles, the all up weight tells all.
If you buy it, use the most powerful motor you can fit in it while still balancing with "NO LEAD".
Set up all of the servos and use the motor to balance it, by sliding it forward and back on the rails.
Final adjustments with the battery.
Good Luck,
Ken
