RE: Maynard Hill TAM 5 Aspect Ratio
Typically -you get that holding -or from trim --a bit too much down elevator (as in tail heavy) - -it then occilates a bit -
so a jerky rotation that tries to actually flip over (under)- has not enough energy settles back into rotation - these little flat foam things -so often derided by others are fascinating to play with.
