RE: engine swap ?
The OS 46 AX should bolt right in. The mount pattern should be close. Another choice would be the TT 46 pro. I believe they also have the same or very close mount pattern. And lastly I believe that the Magnum series would about bolt in. Any of these would be a good choice.
As a side, if you are not concerned about a direct fit replacement I would reccomend the following:
Enya 50 SS, Irvine 45 and 53, Super Tiger GS 45 and 51, Magnum 52 XLS, and MVVS 49. Any of the above would do well in your plane.
Mark Shuman
