RCU Forums - View Single Post - Engine stops running
Old 10-16-2004 | 03:53 PM
MrMotor
Default RE: Engine stops running
OS produced both ringed and ABC type FSR 40s. You may be running it too rich and wearing it out right away. The ABC engines have an oil retention groove on the piston as compared to a conventional ring. You need to get the carb air opening wide open after starting and control the speed with the high speed needle only. The low speed adjustment is a slot headed screw recessed in the center of the throttle arm.
