RE: Evolution TPS .46
Hi friends
Good tha te problems whit the Evo are fixed.. my history, 3 months ago i can get a RTF (EASY STAR) whit Evo and the 5 chanells radio that come with the pack, i have to many problems whit the plane, the incidence angle is not right, with the trailing edge of the wing raised about 1/8 the plane still wants to go up, i have checked the CG, The engine angle etc. and nothing, the engine is very hard to tune on idle, and when is on the air maybe 4 or 5 minutes the engine rpm's are very variable from top to midle , i landed the plane and on the ground all is ok, about the radio, i don't know if the problems is the radio or a bad servo (all electronics come installed) the last flight the plane made 2 loops alone, inmediatly land the plane and perform radio check with and without engine running ,all looks good, again on the air, 3 or 4 minutes and the plane again made a loop, the engine start to fail and the better was to land it and go home for better check...
Any comments?
