RCU Forums - View Single Post - Shock flyer build tips
Old 10-17-2004 | 08:06 PM
Flypaper 2
Default RE: Shock flyer build tips
Had the same problem but finally fingered it out. Where the front and back fuse halfs join together is where you measure from. 15mm ahead of that, make a horiontal line. The square hole in the wing lines up with that line. Hope this helps.
