RCU Forums - View Single Post - Engine Issues - bubbles in fuel line
Old 10-17-2004 | 08:12 PM
mikecdrew's Avatar
mikecdrew
Default RE: Engine Issues - bubbles in fuel line
Will try the fuel tank. I and the instructor tried
[quote]ORIGINAL: Technito20
It's still a possibility it can be too lean. Remember, turn the needle valve one click at a time. Also the engine can be lean on the low end. Try and richin up the low intake valve and see what happens. But make sure you only richin up a 1-3 clicks at a time, because that screw is very sensitive and can be hard to get adjusted properly.
