RCU Forums - View Single Post - Engine Issues - bubbles in fuel line
Old 10-17-2004 | 09:51 PM
bubbagates's Avatar
bubbagates
My Feedback: (32)
Default RE: Engine Issues - bubbles in fuel line
No problem. I had that happen to me once and now if I run into it it's the first thing I do. It's amazing just how many I have fixed like that, especially Evolution engines. There is usually a small hole right at the needle valve and since this is usually a clear line it's very hard to see it.
He did mention that the bubbles were in the line between the carb and needle valve so it was the first thing I thought off. Assuming the line from the tank to the needle valve has no bubbles in it I would replace the line first then do everything else that everyone else suggested.
ORIGINAL: CeeGee
Oops. Thanks Bubbagates. That is very likely as well. I forgot that one. (replacing the fuel to the carb.) That happened on mine as well. It seems like everything that could happen on my Avistar did happen. I sure learned a lot though.
