RCU Forums - View Single Post - 28% edge pics
Old 10-17-2004 | 10:48 PM
Tricktrack
Default RE: 28% edge pics
Flight update,
Getting the trims and percentages dialed in on this plane and it just keeps getting better and better. My original CG was very close the the 5" mark and I am experiencing hands off flight on level upright flight and dead level hands off flight when inverted, so I have not touched it. The amount needed to dial in knife edge is going to be very very small, almost unnoticeable but needed.
Once the trims and values have been dialed in including increasing expo and decreasing the throws from the first flight, I can not say enough about this plane. It flies as true as anything that I have seen (I havn't seen a lot though). Rolls are very axial and in fact if you do more than think about any up or rudder in multiple rolls, I will loose my line because it flies hands off in both positions. Snaps and very tight and the over all tracking of the plane is unreal. You really only need to point it where you want and it stays on that heading. With high rate elevator flat spin was a piece of cake. I have yet to try anything with hovering and harriers but hope to get some experience with them on this plane as well.
Really a fun plane to have!
