RCU Forums - View Single Post - 4*60 fuselage reinforcement
Old 08-13-2002 | 02:32 AM
rajul's Avatar
rajul
Moderator
My Feedback: (58)
Default 4*60 fuselage reinforcement
Originally posted by Volfy
I will be using 3/8" and 1/4" tristock to tie the sides together better. Also, CA the fuselage one joint line at a time and press the parts together tight till the CA bond take set. No need to go nuts with reinforcement, just more gluing surfaces for the fuselage structural members to take hold.
Hi Volfy, could you possibly show some pics of your reinforcement areas? Hopefully you have not covered yet. Did you apply the tri-stock in the first and second sections behind the wing, or only in the first section ? Why do you need two sizes of tri-stock ? Thanks again................
