RE: Phoenix-10 controller question
Lithium batteries can be damaged of even fail completely if they are discharged below 3 volts per cell. The Phoenix 10 can be programmed for a 4 , 5 , 6 , 7.2, 9 12 volt cutoff. You could set the cutoff at 5 volts--the recommended 2 cell cutoff and carefully monitor your 3 cell pack when flying
