RCU Forums - View Single Post - Ryobi
Thread: Ryobi
Old 10-18-2004 | 03:47 PM
BillS
Default RE: Ryobi
I tacked a new box stock Ryobi 31cc string trimmer with straight shaft and got 8100/8200 RPM. Nothing was disassembled or touched not even the carb adjustments. The test was no load except string in the trimmer head.
Eventually every prop imaginable will be tested. I may reassemble the other engine back to box stock and check the RPM. Do you know the RPM of maximum torque? Does the magneto limit the RPM?
