RCU Forums - View Single Post - Pull Pull Set-up Question
Old 10-18-2004 | 06:37 PM
khodges
Default RE: Pull Pull Set-up Question
What plane are you doing the pull-pull setup on? Sometimes due to working space inside the plane, it might be easier to put the adjusters and clevises on the rudder arm--allows you to make adjustments outside the plane, and some low-and-slow scale models have them there for scale appearance (J-3 for instance)
