RCU Forums - View Single Post - Winterizing Your Turbine
Old 10-18-2004 | 08:00 PM
joeflyer
My Feedback: (49)
Default RE: Winterizing Your Turbine
OK, all of you warm weather guys don't need to rub it in. Someday, when I retire I'll more to a warmer climate. In the meantime should I do anything special before my turbine sits for the next 6 months?
AJ,
Thanks for the input. The Ram 500 doesn't have a separate lubrication line. Oil is mixed with the fuel and a certain amount of fuel is diverted to the bearings to lube them. I was wondering if I should run some oil down the fuel line to coat things.
Joe
