RE: Winterizing Your Turbine
Yes, the wren is the same (as are my other engines) and I just put a little oil down the kero line. Just pinch off the line to the fuell needles and blow a little oil down the lube line. You will of course have to remove the cowl to get to the Y connector under there.
AJC
