U Can Do 3D
[QUOTE]Originally posted by FilipM
[B]Maybe you guys still building the plane mount the rudder servo under the fuselage with a short pull pull cable setup to the rudder.
Do not blow this out of proportion, nothing other than a simple piece of brass tubing needs to be soldered over the supplied rudder push rod. Even a piece of 1/4" sq. hard balsa could be added, just wrapped with thread to attach.
Rob
