RE: ball bearings
There would not be a bending load on the rod, the tension would be on the crankshaft between the tapered roller bearings. I only mentioned the fact that it would take two opposed to each other in response to someones suggestion that one could be used for a thrust bearing. It would not be practical anyway since ball bearings do the job so well and the thrust load on them is a small fraction of their capacity.
