another suggestion I learned recently is put the rudder on the aux and the steering servo on the rudder channel (4).
This gives you full deflection of rudder on takeoff and landing but with rate switch for steering.
The only problem is that aux 4 and 5 do not refresh at the same rate as the primary channels not a good idea on a primary flight surface.
