RE: Winterizing Your Turbine
There is something i dont uunderstand. I builted a MW54 and the lub line go directly on the front bearing, the rear one get oil by 'mist' so it takes a fair amount of air to 'push' the oil from front to back...So i think that only the front bearing get oil if you had oil on the lube tube. So how can we put oil on the rear bearing???
