RCU Forums - View Single Post - JR 10X Programming Question
Old 10-19-2004 | 11:10 AM
RCUser012
Guest
My Feedback: (73)
Default RE: JR 10X Programming Question
now how do you do the following :
2 bombs to drop, snap roll button only drops one at a time, based on flipping a selector switch for the desired bomb .. i have it set up where i use the original dial for ch10, and mix an offset with the use of the snaproll button , so if the dial is all the way in one direction, the button ofsets the travel to full deflection (im using the BVM bomb drop set up for the king cat) ... when the knob is at center, the button has nothing to ofset and therefore will not do anything .... .. i was unable to find a way to take the "selector" function off of the original aux5 controll knob ... seems like you can not throw a mix on top of a mix ???
i also have the snap roll button set to throw an overtravel ofset onto the gear channel.. i have a JR channel expander on this channel .. gear up and down is defined on the ch expandedr, and when the gear is up, allows the overtravel to kick off the smoke pump via the ch expander (smoke and gear on the same channel )
i still would like to move the bomb sellection off of the knob and onto a 3 position switch (hopefully a D/R switch as im using the aux 2 switch for the aux channel needed for my AMT turbine )
Wojtek
