RE: JR 10X Programming Question
Do you have Flight Modes enabled? Just asking because if they are active, it limits the number of other switches that can be used to control program mixers. As far as I know, you will not be able to use any of the D/R switches to control a mixer, not withstanding the D/R switch that is used to select Flight Modes if they are enabled.
I don't have a TX here with me so I can't be sure, but if Flight Modes are not active, you might be able to use the 3-position Land/Flap switch to control 2 different mixers to get the job done.
Len
