RCU Forums - View Single Post - Pull Pull Set-up Question
Old 10-19-2004 | 05:23 PM
voyager_663rd
Default RE: Pull Pull Set-up Question
ORIGINAL: khodges
If you're using a computer radio (and I assume you are with multi servo setups) you can program the Tx to reverse one of the elevator servos- you don't need a reverser. There is also a reversing "Y' adapter that will do the same thing, or you can make your own --just clip and reverse the power wires(black and red on Futaba) on one servo lead downstream of the Y. You don't need but a mm. of clearance between the servo arms , but I like all my servos "pointing" the same way.
I do have the puter radio but the elev servos are ganged on a Y so the radio reverser won't work (BOTH would be reversed which is not my intent ). I didn't want to spend the bucks on the reverser. Cheap so and so you know.
HOWEVER, I like the idea of clipping and reversing the wires. So simple and don't know why I didn't think of it. Thanks for that. I also won't have to worry about the clearance issue either, doing it that way.
[sm=thumbup.gif] to you sir (and also to the others that offered their help).
