Originally posted by RCadmin
....but question is whether or not you can get maximum elevator throw at the same time ailevators are activated...I can get full throw out of either one but that is with the stick in one corner but just pulling back on elevator only gives just a portion of the total available throw...
By setting your ATV on both the Aileron and Elevator throws to 140%, and using 100% Elevator Dual Rates, pulling or pushing the stick for elevator only will let both elevator halves travel to the maximum deflection allowed by the transmitter.
Then if you start to move the stick sideways for ailevator mixing while maintaining full up or down elevator stick, you will see one elevator half start to travel back towards neutral, and the other elevator half will remain stationary since it was already at the maximum travel allowed by the transmitter.
Or am I still misunderstanding your question?
