RE: Elevator flutter
re gear it - - any slop in this servo - on a light load will start the self exiting dance.
The rudder on a light setup -for example -a Funtana is a prime example- here is an experiment for you -
reset the center on the servo - withyour trim lever -then re center the surface - chances are the chatter will stop -
You will be operating on a new pot and gear center doing this .
