RCU Forums - View Single Post - OS 61FX Engine Problem
Old 10-19-2004 | 10:33 PM
Tim Taylor
Default RE: OS 61FX Engine Problem
Same Problem Here, Balance the prop! That fixed it. I Bought a smaller tank and installed it too and put retainer clips on all the fuel lines including inside the tank. I put foam around the tank and that helped some. But balancing the prop is the key. I can run full throttle with no foam now.
Tim
http://www.airmadillo40.com
