RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 10-30-2002 | 02:12 AM
  #445
TOMAPOWA
Default Re: Throttle servo...
Originally posted by Cabane
I mounted my throttle servo, a hs81, external in the channel underneath. The rod to the Saito 100 throttle arm is very short. I have the tank at cg. A long snakey pushrod would have to be used otherwise. Anyone see a problem with this?
Hey Cabane,
The area you have that servo mounted,... isn't that going to get full of fuel/oil ?? It also appears to cut down on the air flow through the "channel". After a flight on my UCD3D (4-C, OS91 pumper), that channel is full with oil residue.
