RCU Forums - View Single Post - How many failures are their with Hitec verse JR servos?
Old 10-20-2004 | 07:54 AM
  #38
jmiracle
My Feedback: (9)
Default RE: How many failures are their with Hitec verse JR servos?
What I find interesting is that in nearly all of these threads, somewhere along the line it's discovered that a connection was loose causing poor signal/power to the servo...or that the servos had been involved in a previous crash....or there was a hard landing recently....almost always there's a REASON for the servo failure. I have yet to see anyone PROVE that the servo just failed all by itself with no outside help.....no matter what the brand.
In both instances that I have witnessed a "servo failure" (one of which was my plane that I crashed)...it was later determined that something else led to the servo failure. In my case, an extension vibrated loose, intermittent signal to the servo and the servo went hard-over....stupid mistake, lesson learned....haven't had a problem since. In the second instance the individual later remembered that he had been hovering over a pond the week before and had dunked the tail a little too far the last flight. A week later, and several more flights and that servo gave up the fight. Not exactly a big surprise....but again, lesson learned.
ORIGINAL: Mike Rojas
Nearly every thread that has claimed Hitec servo failure has been becayse of a hard lock over to full deflection,and most of the time with wittnesses. Sure there are plenty of planes crashing due to pilot error and other equipment failure. What is the point that Paul's plane had Hitec's and he dead sticked that led to a crash ? I don't think any is suggesting that there is somekind to Grie-Grie on your plane if you use Hitec's and you will crash one way or another. Is it only people buying Hitec's that don't know how to correctly set up a plane mechanically or electrically, that's what always comes out of these post. Maybe Hitec should place a surgeon generals warning on the box that states"If you are incapable of a 100% perfect mechanical and electrical setup,do not use this product".
Mike
