RCU Forums - View Single Post - Effects of moving weight fore and aft of CG?
Old 10-20-2004 | 09:30 AM
mulligan's Avatar
mulligan
Default RE: Effects of moving weight fore and aft of CG?
Time Pilot,
Sergeant's formula is the one to use to relocate weights on either side of the "scale" and maintain the CG location.
Frankly, I'm not sure what Jim was stating, but I don't suggest you try to calculate the moment of inertia- just doing the things we've discussed will give you the qualitative results mentioned. Just for fun, here are some basic equations on the subject of rotational motion.
moment = control surface force * its distance from cg
OR whatever external forces * whatever relevant distance
mass moment of inertia = SUM (mass of each distinct weight * its distance from cg ^2)
angular acceleration = moment / mass moment of inertia
So, you can see through the formulas the effect of slowing down the responsiveness of the plane by spreading weights out toward the end points. Of course, you can apply this in each of the plane's axes.
