ORIGINAL: backfire
Just curious; what are you doing with the ohm meter?
One uses an AMMETER to monitor current draw during the setup process so that we can be sure that the setup is not binding. Actually - I use the servo "whine" as my guide .. its just as accurate.
If he used an Ohmmeter.. that could explain why he though his setup was OK
DP
