RE: Pull Pull Set-up Question
Hi!
The system I use is in reality what you describe; a short tube (crome plated brass) which I push the wire through...then the wire is pushed into a small hole drilled in the 2mm controll linkage onto where the clevis is screwed.
The wire then goes back into the short tube and then back again.
Then the short tubing is cramped at two places with a plier. You should never crush the short brass tubing as it loses some of its holding ability that way.
See picture of my PBY Catalina (Kyosho).
Regards!
Jan K
Sweden
