u can fuel tank
I'm using a 91 FZ on my U-Can and wanted to use a 16oz DuBro
tank but i noticed the tank came a little close to the fuse sides. I wonder if it is enough room when the tank pressure swells the tank. I'll be mounting it on the C/G and there is not enough depth in the fuse to mount the tank on its side.What are you YS guys doing about the tank set up in your UCD's
Thanks Brad
