U Can Do 3D
olmanbruce,
I run a YS120SC, swinging an apc17x6 at 9500, very fast vertical ha ha, Hovers at about 1/3 throttle, sounds like just above idle. When does your Saito flood? If it's just between fueling and starting, just pinch the line with some forceps, it it floods when taxying out to the runway, and idle is adjusted right, yep, then I guess you'll have to movve the tank. I am purely YS when it comes to 4-strokes, so you'll see me recommend those engines all the time ha ha.
DKjens
