ORIGINAL: prophanger1
would the saito 30 hover it at 3/4 or less power just as long as it could creep out of a hover its ok i can build lite, micro gear.
I'm pretty sure that it will hover the plane at 3/4 or less. My 40 hovers it around 1/2. I think the 30 would be ok. Mine would be considered a little overpowered for the plane, but I like the setup. My plane weighs 3.1 lbs which is a little heavy for this plane actually, so if you built it light, then the 30 would be fine.
That may be best piper_chuck until you can silently observe his flying.
