RCU Forums - View Single Post - Pull Pull Set-up Question
Old 10-20-2004 | 05:03 PM
ez2bgman's Avatar
ez2bgman
Default RE: Pull Pull Set-up Question
Hey voyager,
What pull pull system are you using (what manufacturer)? If you are using a Dubro set up like I did, then you may have a hard time getting the plastic coated cable through the crimp tube 3 times. If you find it dificult, then strip off just enough plastic coating off the cable to allow you to make it through the required 3 times. Don't short-change it and just settle for passing it through twice. If you have any questions, I can post some pics of how I set mine up on my H9 Aresti 40. Good luck to you.
Gary
