RCU Forums - View Single Post - MDS 1.48 needle settings
Old 10-20-2004 | 08:46 PM
kennyandannie
Default RE: MDS 1.48 needle settings
I do my best not to steer you wrong. I'm glad its running good for you. After about the first 1/2 gallon you can start to lean it a couple of clicks or so if you want. I usually run about a gallon through before I start leaning the needle. It takes a while for the 1.48 to break in, but when it does it'll pull you around with the plane if your not careful!!
Gotta' luv' the big ones!!!
I usually replace the plugs in all of my 2-strokes with OS #8's. A great all around plug.
Have fun,
Ken
