RCU Forums - View Single Post - Electro Uproar
Old 10-20-2004 | 09:52 PM
RiffRaff
My Feedback: (16)
Default RE: Electro Uproar
Okay,
Thanks for the prop advice! Like I said, I am new to this stuff. The problem I have is the ground clearance of the uproar. I have 2.5" wheels and the supplied gear wire/rod and 11" seems to be about it unless I change the gear/wheel config.
I am somewhat confused. If I run a 10x5 shouldn’t I slow down over thee 11x6 or 12x6 I have run already? The pitch is 1" less. I figured smaller pitch would slow me down and smaller diameter would increase run time (and same me some broken props, Doh!)
I may have to raise her up a bit and run like a 13x4 or something.
Still learning but your advice is well received!
Riff
