RE: Cant reassemble Diff!! help!!
No,
Running it too tight will just wear out the diff rings and diff balls quicker than normal
Also running them too tight will cause the trauck to spin out easier in loose conditions
Running the steel diff gear lets you run the slipper a little tighter, but you still have to worry about the idler gear.
Adjust it just the way the manual suggests, it will last a long long time with it adjusted correctly
Party on Garth
