U can do 3d set up of dual elevator servos
Has anyone had trouble getting the two elevators halves to match up throughout there full up and down motion? I tried different linkages. I thought about using a JR Match box, but was told would not work. I was told you need to get the linkages equal lenghts. But how when on the U-Can Do 3D when the servos are offset. Using Hitec servos, new Karbonite gears , not digital on elevators only rudder. The radio is a Futaba T6XAs. Would the 9CAP Futaba radio allow the cure for the problem. Elevators are equal in nuetral position but one half has more up then the other, then the opposite occurrs when down is applied. They still return to nuetral. Seems that because the servos are reversed there is more throw at the opposite endpoints. Would a servo reverser work the allowing the servo arms to both be mounted in the same direction work. I have seen the reveiw in RC Univers and the servos are mounted differentl then in the Manual that came with the plane. Any suggestions would be helpful.
