RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 01-02-2003 | 11:39 PM
  #735
FalconWings10
Default U Can Do 3D
I'm not sure that you can cut 4-40 threads with a die because the diameter of the rod is not the same as diameter of the outer threads. I have run into this problem when trying to cut threads. I was told that the manufacturer "rolls" - "presses" the threads; thus, squeezing the diameter of the rod causing the rod diameter to be too small for thread cutting.
