Hehe, Yeah, it was definately happy it made it down in one piece
. I had originally cut a small opening in the nose, but was concerned about airflow, so I opened it up. The square box wasnt cutting it from a style standpoint, so the CanUDo got a facelift hehe.
My tank (8 oz)is not quite on the CG. It ends just at the leading edge of the wing. My tank pressure was a little low on extended verticals (not good in TR), and I didnt use my perry pump. I could run the pump and have continuous pressure, but I'm going with the 91 FX. Twice the power, and more prop. I'll prob go with the stock tank, and push it back to the cg, if I can figure out where to put my receiver and throttle servo. I could move them to the rear of the fuse, if my extensions are long enough. (Theres a thought). I already have an access hatch cut for the battery. I might also go with a 6 volt pack, for more speed/torque.
The pull pull worked great. I may tighten a couple of turns of slack out of them, if I see they are wandering a little.
