RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 01-04-2003 | 03:58 PM
  #767
DKjens's Avatar
DKjens
My Feedback: (50)
Default Fuel filter
coomarlin,
A filter between filler and tank would just catch dirt when you fuel up, then dump it in the engine when running it. A filter should be the last thing the fuel encounters before reaching the engine, so between filler and engine is the correct place. Also run a filter on your filler hose from your fuel storage container.
I ran my antenna through a hole on top of fuse, right behind canopy, down the top of fuse, to the root of the vertical stab.
DKjens
