RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 01-12-2003 | 12:02 AM
  #799
archer
Default U Can Do 3D
What propare you using on the OS91 Surpass? I have that engine in mine and at altitude of about 500 feet. I am using this plane to learn acrobatics, but even mine will hover and pull out slowly on only 5% nitro. I am using 15x6 wide blade. I just picked up the 14x6 standard (both APC) to see if the engine will spoil up faster to pull out better, but hovering is easy with this plane.
Our 3D flier uses the same set up and has no probelms at all, but he is using more nitro.
Unless you are at high altitude, you should not have a problem hovering. Pulling out instantly with the surpass is another story.
