RE: 46 OS Inverted Trouble
I think Wearden's got it right. You're probably flooding the engine if you're running too rich, which might be the case if you are just breaking it in. I would recommend that you remove the plug and check to see if fuel has accumulated in the glow plug.
Also, it may be that you have the fuel lines mixed up. I know it sounds silly but you never know.
