RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 03-26-2003 | 09:15 PM
  #881
coomarlin's Avatar
coomarlin
Default Re: more questions on YS 91 setup
I really don't have any comment on the inverted PItts muffler with the YS. I haven't tried it. I, just like Morbid and about 1 million other people, use a Saito 100 in my UCD. (The other million use the YS it seems).
I wouldn't bother using a high pitch prop on a UCD. That is not what the plane is meant for. I would suspect that flutter could be a problem with a high piched prop. These control surfaces are huge.
I forgot to mention that I'm using a 6V 1650mah NiMH battery so the torque I'm getting from my 3001's should be somewhere near 60oz. I went to 6V specifically for that reason. It also speeds the servos up a tad, although it's not really noticable.
As far as modifications, I made a few. I went with 4-40 pushrods on the control surfaces instead of the supplied 2-56 rods. I mounted my fuel tank about 3 inches back and used a cline regulator on my Saito. I did not use the stock tail wheel assembly because it felt cheap and weak. I used the sullivan instead. Other than that the plane is pretty much stock. You might look at beefing up the landing gear block as I've heard of a few people complain that it's weak. (Although I haven't done it). But for $189 the plane is a good deal. It's a big plane with loads of tricks up it's sleave. You'll like it.
Originally posted by wood
Ok, now I'm starting to get interested in this one. I have a few more questions for you guys on this engine install and the airplane in general.
1. Did any YS 91 owners use an inverted pitts muffler, will it fit?
2. Can you use a prop greater than the 6 pitch that is recommended and get away with it, anyone had problems with flutter?
3. Here are the specs on the Futaba 3004 servos from the tower web site. This still makes me wonder if it will be OK to use the standard 3004's, they are close at: 44 oz, they say at least 50+ oz.
SPECS: Speed: 0.23 sec/60 degrees at 4.8V
0.19 sec/60 degrees at 6.0V
Torque: 44.3 ounces-inches (3.2kg-cm) at 4.8V
56.8 ounces-inches (4.1kg-cm) at 6.0V
Specs on 3001's that came with my 9CAP are the same, I thought they were stronger servos...........
4. Any modifications needed other than what is in the instructions?
5. Any complaints on this airplane from anyone?
WOOD
Heres some more information from the tower web site, they want to sell you a t6xas with standard 3004 servos, and two 3003 servos, so they must have tested it with these and work ok.
http://www2.towerhobbies.com/cgi-bin...T=2&I=GPMA1270
