RCU Forums - View Single Post - How often does Trim need to be set on same plane
Old 10-21-2004 | 03:46 PM
campbec
Default RE: How often does Trim need to be set on same plane
In addition to the great information already offered I would suggest that once you have trimmed the model that you use your control throw meter to set the adjustments mechanically and then zero your radio trims.
I certainly have found that occassionally a click or two of trim is required on previously trimmed models.
Cheers,
Colin
