RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 04-14-2003 | 12:45 AM
  #961
nosram
Default Saito 100 prop
I have a Saito 100, I have tried an APC 16*4... this was good but bogged the motor down. An APC 15*4 revved too high, and was lacking mid range grunt. An APC 15*6 was by far the best, much improved torque roll and waterfall were the result
quote:
Originally posted by Webjammin
Just tryin to follow this long thread is making me dizzy
Here's what I've got going on with a UCD3D. I was first going to put a 61FX in it but after asking and reading here on RCU that the 61 will fly it with little power to spare.
I went down to my LHS and picked up a SAITO 100 for some better power, It looks to me that the Saito carb placement won't have a fuel siphon problem.
So now that I have the Saito 100 engine a couple more questions:
1) best if mounted inverted ?
2) should engine thrust angle be set right with a (2) washers under left side of engine mount ?
3) what pitch prop is best for the Saito 100
4) is the stock fuel tank large enough for the engine ?
More questions to follow
Bob
